dirty air filter, condensor, sparkplug, coil. i would start with the plug and clean the filter. plugs will break down as they get hot. probably 9 out of 10 times small enging problems can be traced to the sparkplug.
drop the float canister and check that bolt you have just removed there is a little hole in it(on the threads) that the gas goes up into the engine piece of grass might be in it should be able to blow thru it
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
