i'm installing a new bathroom in the basement and will be roughing in water lines for a toilet and shower. Since it's the basement, finding both a hot/cold water feed was not a problem. However i'm a bit weary about soldering but found a fantastic alternative called PEX. couple of quick questions here tho
1. is it bad if i split my copper lines and install a T connection that connects to a PEX pipe?
http://www.youtube.com/watch?v=eQGL8MBLlaE
2. how do i secure the PEX piping to the wall? same bracket as the ones the brackets for copper lines? does it need to be secured at all??
3. can i split (T) a PEX line?
4. for a toilet water line and showers, isn't it required by code to have shut off values? if so, it seems like having copper line maybe a little more rigid??
