Hello all,
I modified a circuit (few months back added lights to my kitchen), and after first inspection inspector asked for me to put a AFCI breaker on the circuit I was touching. That circuit is a MWBC (older house). The breaker covers a MWBC 15A circuits 6 and 7, which is pretty much my 2nd bedroom/bathroom & outlets (circuit 6) and kitchen lights + 1 kitchen outlet (circuit 7) respecitvely. I was using the 2 old breakers (6 and 7 here http://snag.gy/3cCv6.jpg) until I installed the 2-pole AFCI.
I had it inspected and signed off - inspector checked it was all OK, even checked the AFCI wires in the panel box.
Pre-cursor: I installed the breaker on the weekend, replacing the old siemens standard breaker. Had it all inspected later in the week. It tripped a day later when I flipped a three way switch on circuit 6 (I never touched anything on this circuit). When I reset the breaker it tripped a few seconds later. It wasn't until I went upstairs and unflipped the switch (leaving the light on) and then reset it that it worked. A little while later I flipped the switch off at the other end of the three way and all was fine. Odd but I noted it down for me to look at this weekend (maybe a wire nut is loose at one end of the three way or something). Figured as I didn't touch that part of the circuit, the AFCI breaker is a picking up something a normal breaker wouldn't. I was going to investigate that lighting circuit this weekend until..
Fast forward to today I had a heater connected to an outlet on circuit 6 and then my wife plugged a vacuum in and turned it on. Lights flickered a few times then I heard a big bang (not a gentle trip) from downstairs where my breaker panel is. Went down to have a look and could smell a little electrical burning. Unplugged the heater and vacuum, then after a while tentatively flipped it back on. Sparks flew out the side of the breaker (wire side), lots of noise, and then it tripped again. Electrical burning smell definitely stronger now.
What's the diagnosis? How could this happen? I presume the (expensive) breaker is screwed. Overloading the circuit should just make it trip. Not destroy it. Thinking this thing is a fire hazard. So much for installing a safer breaker. Pigtail goes to neutral bar, neutral from MWBC goes to the load neutral breaker terminal. One possible thing could be using a wire nut to connect the pigtail to the neutral bar, rather than a direct connection, but I can't do much about that as the pig tail isn't long enough on its own.
Thanks
Thanks
