1 - 12 of 12 Posts
Beer Advocate
My nailer is trying to kill me! :mad:
I got nails for my Porter-Cable framer today and happily was ready to put my first stud in. I bought this porter cable used off ebay, got it for 60 bucks. When it came in I hooked it up at work and fired a dozen nails or so. Everything worked great and I was happy to of saved some money. Today I hooked it up, placed it on a test 2x4 and fired. It jerked up and I notice I had sunk 2 nails into the wood. One actually on top of the other. I figured I wasnt holding it tight enough and it bucked or something. So I tried again. Same deal only 2 nails side by side this time.
Whats the deal with this thing? What causes that to happen, and what can I do to fix it! :(
Obviously I am going to be forced into breaking out a hammer tomorrow. :furious:
Thanks!
EDIT:: Ok so I just went out and looked around I found one user reporting that if its in rapid fire mode it can cause novices to double fire. I didn't even know this had 2 modes of fire, so if its a switch it must of got hit when bringing it home. Going to go down and look at it, I didn't see anything to switch onit. Infact all the air adjustments even must be done with a wrench. *shrug*
Lic. Builder/GC/Remodeler
Check your nails...the ones you purchased. They may not be the right angled nails. I believe the PC takes 22 degree nails (?).
Check that out....It's got to be the nails, since the other nails worked fine....
It sounds like you have a unit made for bump firing, with a contact trip trigger
it takes a little getting used to. don't jam it down like a
Trak-fast gun, but instead let it bounce up a little after the nail discharges. Be careful, but you'll get the hang of it
I don't know about PC units, but Bosch color codes the triggers. A black trigger means it is a contact trip set-up ( which i am guessing you have) This means if the trigger is depressed and you bump the nose it will shoot. i have seen three nails at a time
a gray trigger is a sequential trip trigger ( which is safer for low volume DIY use) this requires the trigger to be pulled once for each nail
think of a machine gun, you have an automatic instead of a semi-auto
Beer Advocate
Discussion Starter #6 (Edited)
The nails are exactly the same so you picked out the right ones for me AtlanticWB. I wrote down the model off your previous link and got a box of those. :thumbsup:
I have a black trigger, so thats how its changed! So I pull the trigger and can slap the nose around and keep firing non-stop? Crap, I would infact rather have it the other way! Can I change the trigger or was that model specific?
I have a PC 350 and I contacted customer service-- they sent me a different trigger free. The new one is a red trigger for single shots.
Custom Cabinet Maker
my 350 will do that also. most often it is caused by the recoil. Nose lifts just enuf to reset the safety and double fires. Hard wood will cause it also, same reason. lower ur air pressure to 80 ish,
Yeah cabinetmaker and a framing gun LOL
Beer Advocate
Discussion Starter #9
Thanks for the tip, I will try a lower PSI setting. So in all reality the tip should not trigger it twice, it being caused by the "bounce" from recoil. I will contact Portal Cables customer service about the trigger also. I will have to get use to it for now though since tomorrow will be a dedicated day to work on this.
Thanks for all the help
Try just using the very tip of your finger on the trigger till you get use to the gun, I have had luck teaching people this way on my guns with that type of trigger. Most will companys send you the other type of trigger for free, other wise they could get sued if you shot yourself
That's good advise.
Most people start out, by grabbing a pneumatic gun and the trigger, like they are going to use "it" to pound the nail in...:laughing:
Beer Advocate
Discussion Starter #12
That's good advise.
That was my problem, I thought I would need everything behind it holding it down so the nail sunk all the way in. Since I have eased off I have not had 1 miss-fire all day! :)
1 - 12 of 12 Posts
