Hello,
I live in Texas, and my A/C units are in an unconditioned attic. There are two units. One has five 8" ducts and the other has three 10" ducts and one 12" duct. Almost all of the ducts are metal ducts with a few short sections of flex duct. There are no return air ducts, air goes directly from the filter to the return air plenum to the unit.
When I was finishing up my radiant barrier project, I noticed that I felt some leaks coming out of some of the ducts, near the plenum. There was mastic glommed all over the ducts so I stripped it off. The ducts are attached to the plenum with sheet metal screws (good), but there are some gaps and the gaps were sealed with duct tape. (very bad). The duct tape degraded over time and air ended up leaking.
For these leaks I strip off the mastic and duct tape, put down fresh foil tape. Then I have been using "duct sealant", which is grey stuff the consistency of paste. Should I be using mastic over the metal tape?
Also, there are some gaps between the plenum and duct and also between the plenum and the A/C unit. Some of the gaps can be a quarter inch or so. How should this kind of gap be sealed up? Are foil tape and sealant sufficient? Should I use some kind of caulk? Or perhaps a strip of aluminum to bridge the gaps?
A lot of the seams in the ducts are sealed with duct tape. Many of these seams look perfectly fine. Should I strip off the duct tape on the seams that look okay and replace with foil tape and sealant?
Which seams, if any, is it absolutely necessary to use mastic on?
TL;DR What's best practice for sealing ducts?
Thanks,
Cakemeister
Thanks,
Cakemeister
