Imo, perfectly normal. wh probably doesn't have heat traps and some of the water sitting in the pipes for awhile will be warm till it runs for a bit. Just my opinion.
Just seems strange that it has never done this before & we have lived here for many years & have not had any plumbing work done in years.Imo, perfectly normal. wh probably doesn't have heat traps and some of the water sitting in the pipes for awhile will be warm till it runs for a bit. Just my opinion.
Not sure how old it is jmon but it is a GSW SERIES 6. Model 6G50SD1
Thanks for your reply Thomas but we have lived in this house for many years yet this is a new phenomena.Also if your second floor pipes run next to heat ducts in a common chase water in the pipes can get warm.
Thanks for your reply Eplumber but as you can see from my first post the cold water line is warm long before the water gets to any faucets.Do you have any Moen single handle faucets or tub/shower faucets. They can fail and allow water to pass cross the faucet while it is off.
Thanks again. Once I find the age what should I do with that info?find your serial number then use link to determine it's age.
https://www.building-center.org/gsw-water-heater-age/
This can be an indication of a failed faucet cartridge.........:wink2:I have a strange situation & hopefully someone can help. Warm water is getting into my cold water pipes
I made a big mistake with the explanation in my original post. The pipe highlighted as #1 is the pipe leading from my well, the pipe highlighted as #2 feeds the house with cold water but the pipe feels warm. The pipe highlighted #3 enters the top of my water heater tank.This can be an indication of a failed faucet cartridge.........:wink2:
Please itemize all the components of your domestic water system. This will help with the 'guessing'
This is for the GSW parts catalog. http://www.gswpartsonline.com/
