1 - 20 of 24 Posts
· They're all fixer-uppers
I am taking up my tile floor in the bathroom and I'm going to retile. The tile floor in the bathroom is considerably higher than the hall floor and I found that not only has tile been tiled over tile Which was tiled over tile, but the mortar bed below is really thick. The problem is, my closet flange sits a full 1 3/4" off my plywood subfloor. I was going to use 1/4" hardie and a 1/4" tile. The Flange is cast iron... the flange is going to be too high for me, right? I mean, even I bump up to 1/2" backer it will still be too high, right? What is the highest the flange can sit atop of the finished floor?
Bottom line is that it has to sit "on" the flooring. It should also be attached to the floor with screws. Hopefully, you have access to the area under the floor and can cut the cast iron pipe and lower the flange to fit your new tile height.
The bottom of the flange should be sitting on the finish floor.
the only way to fix that is to take the flange out and lower it. My suggestion find an older plumber use to working with cast iron and have him fix it. he would probably be over 50 to have enough of experince to work on cast iron. I am 55 and they were phasing out cast iron when I came into the trade in the 70's. Although it is still used on some commercial jobs for noise reasons. It is much quieter than pvc.
It is not your your only option if you have access under the house. You could cut the cast iron and put a No-hub or Fernco coupling and switch to PVC. This way you could lower the flange to the proper height.
no its not your only option.As stated above if the pipe is accessable from underneath you can try doing it yourself by cutting out the cast iron and replacing with pvc Using either a fernco or no hub band. If you decide to do this I would recommend using a transition no hub band to go from 4 inch pvc to 4 inch cast iron. The reason for this is the pvc is slightly thicker than the cast and it makes the transition look and work better as the thickness difference is corrected in the no hub band. This is of course you are working with 4 inch pipe which most likely you are. The transition no hubs are available in other pipe sizes also.
Depending on the age of your home, the cast iron may be connected with No-hub couplings. I did a lot of jobs like that in the early 70's. You would still need to get a cast iron to PVC coupling. If the cast iron is hub type, with poured lead joints, it is a bit more work.
<~~ not a fan of hardy boards in bathrooms. Consider putting down a mud floor of portland and sand.( 5 parts sand, 1 part cement) You can perfectly level the floor and and its a much better base for tile and you can raise your floor that way.
It is good you have access. You can make the floor the height you want it to be. Working with cast iron overhead is very difficult so unless noise is an issue I would replace the cast with PVC or ABS all the way to the stack. You can use rubber bushing that goes into the cast iron hub or a coupling that looks like a short rubber pipe with a stainless steel clamp around it to connect the plastic to the cast.
Discussion Starter · #18 ·
Ok, I haven't seen the side of the stack that the stub comes out of. See the hub that is visible behind the arrow? The stack is directly on the other side of that wall right there, literally up against the plaster in fact. So is that hub right there the one you are saying I should go into? I'm sorry I'm not following very well. I was thinking I would cutting about 6" or so away from the hub and using one of these
If there is an easier or better way? I wasn't sure if it would be easier/better to cut along that horizontal run where the arrow is, or along the vertical run just below the sub floor.
You are exactly on the right track. As close as you are to the stack I would not cut anything. Once you get the old flange out of the way and make sure the cast is not attached to the joists you will probably be able to wiggle what is left out of the hub in the stack. Just be careful not to move the stack. You can carefully dig out the lead with a chisel or apply some heat to melt the lead and it will come right out. When you get it out it will be heavy. Be mindful of what will be damaged if it falls… feet, tools, nicely finished floors. You can use a hub bushing to start your PVC or ABS plastic from the stack. You should choose between PVC and ABS based on what is accepted in your area. PVC is the most common.
Leave the new pipe at least a few inches higher than the new floor. You will be able to cut it and make the new flange sit on the new floor where is should be. Be sure to screw it down properly. Once you get the old cast out the hardest part will be getting that bushing to seat. Use something like dish soap to help it slide in.
Rege
Discussion Starter · #20 · (Edited)
Rege
Ok sounds great. I thought cutting was my only option, I didn't realize I could dig out the hub. I think the hardest part of everything will be coordinating everything - this is our only toilet. Thanks for the info!
and this is the bushing I will need, right?
http://www.fernco.com/img/products/plumbing/donuts-orings/do-multi-tite.jpg
1 - 20 of 24 Posts
