First thing ., the bedroom do required AFCI breaker now they adpoted the code last year and use the 2008 NEC codé editon for details and IIRC there are couple more change with state code { Comm 16 } I have to check the latest edition due I am in France for a quite while now.I am rewiring part of the second floor and have a quick question. Are MWBC still allowed? Right now the whole second floor(3 bedrooms and bath) are on one circuit. Can I run a 14-3 upstairs and put 2 bedrooms on one curcuit and the other bedroom and bath lighting on the other branch? These used to be fine but thought I read somewhere the codes changed with MWBC.
Thanks
This is just for the outlet right? The lights can go on with another 15 amp circuit still can't they?Also the bathroom needs a 20 amp circuit dedicated to the bathroom only.
Thanks Marc. I am just going to run two 14-2 wires up the wall. Along with a 12-2 for the bath outlet and a 14-3 for the smokies. I always try to do things right while everything is apart, unlike the guy that gutted the house 10-15 years ago and left a mess of knob and tube for the next person(me) to deal with!First thing ., the bedroom do required AFCI breaker now they adpoted the code last year and use the 2008 NEC codé editon for details and IIRC there are couple more change with state code { Comm 16 } I have to check the latest edition due I am in France for a quite while now.
My home back in Wiscosnin I am in East side of ya.
So to the point no more MWBC in resdentail useage unless you find 2 pole
AFCI they are not cheap merde., { the last one was about 80 Euros }
Unless you check with big orange to see if they have 14-2-2 NM cable { kinda special order } otherwise just a pair of 14-2's will work just fine.
And just be aware with Wisconsin did change one codé related to the smoke detectours It have to be hardwired when you remodeling and also you will need carbon moxide alarm one on each floor { unless you have all electrique aka no gaz or oil burning devices } { the law went in effect earlier this year }
If more question just holler I will steer ya in correct way.
Merci,
Marc
Is there any downfall to this?If the lights and fan are on the bedroom circuit then they will also be on the AFCI circuit.
None that I know of.Is there any downfall to this?
Thanks for your advice
None AFAIK.,, as long you termated it properly.Is there any downfall to this?
