I prefer to call it discussion, and I have been discussing this very issue for 20 years with Architects, General Contractors, and Masons, to say nothing of chemical manufacturers. You either did not read it thoroughly, or did not completely understand what they are saying. All proprietary new construction masonry cleaners contain acid. They also contain buffers and other chemicals to reduce or eliminate some of the hazards of doing so.
Hansen brick recommends the use of ProSoCo proprietary cleaning products, as do most brick manufacturers (or equal). None recommend the use of unbuffered muriatic acid.
From The Brick Institute of America, tech note 23, "Identifying Stains":
"Some brick develop yellow or green salt deposits
as shown in Photos 7 (yellow) and 8 (green)
when they come in contact with water or unbuffered
hydrochloric (muriatic) acid. These stains
are usually vanadium salts. They may be found
on red, buff or white brick; however, they are more
conspicuous on lighter-colored brick."
"Unbuffered hydrochloric (muriatic) acid should not
be used to clean tan, brown, black or gray brick."
From The Brick Institute of America, tech note 20, "Cleaning Brickwork":
"Do not use unbuffered muriatic acid"
Both from bia.org, Technical notes.
Please note that this information is designed for contractors. Homeowners should not even consider using muriatic acid for cleaning anything. It is a dangerous material to mess around with.
