1. So since I've been in my house there has been a 100amp panel in my garage but is not wired properly and I want to fix that.
I am looking to see what wire I would need to supply that panel from my main panel? I will probably be going with conduit above ground around my house. I'm looking upwards of 60-75ft run.
2. Will be doing a heatpump system and looking to see what wire I may need for that. From what I have found is that the plan is to use my exhisting breaker from my wall unit that will be disconected and running that out to the heatpump unit(mini split) and that is currently a 20 or 30amp. What size wire would that need to be and this will be run in conduit also above ground about a 20-30ft run?
3. can both these runs be done in the same conduit?
4. Also looking into a generator input box on the outside of the house and doing one of these kits... http://www.interlockkit.com/feedthrough01.htm since my utility is a pain about having a dpdt meter box put in or anything to do with a generator behind there meter. And the room with the main panel is a bedroom and is finished so can't do a seperate panel. Coult that be run out the same conduit from the wall?
