Multiple "pilot" wires for heaters at the electrical box. How to figure out which is
Hello,
The heating system in my house uses electric heaters. Each heater has a "pilot" wire that runs to the electrical box, along with the load and neutral wires.
The pilot wire is connected to the control system, which then sends a signal to each heater to turn it on, off, daytime, day-time.
The control system has two "zones", and so the pilot wires can be grouped into areas of heat. (ie: Zone 1 = bedrooms / Zone 2 = everything else)
The problem is that I have no idea which pilot wires are for which heater. They are not labeled.
Is there any way I can figure this out? For example, I thought about putting a 9v battery on one end of the wire and then a multi-meter to check for voltage... but I need two wires for that, and the pilot wire is only a single wire.
Any ideas?
Thanks!
Hello,
Any ideas?
Thanks!
