Over the last several years, I've slowly been correcting issues found during the inspection of my house performed during purchase.
One such reported issue is that the outlets in 2 of my bathrooms are not GFCI. I decided to install GFCI outlets in both, not thinking much of that fact that they are on the same circuit.
After installation, I realized this makes the reset process a bit cumbersome. To make matters worse, I discovered that a GFCI outlet in a bathroom on the other side of the house is also on the same circuit (upstream from the others).
Some Google searching has led me to believe that there's nothing inherently wrong with multiple GFCI outlets on a circuit except for the awkward reset process.
Since I already have them installed, should I just leave them in or would it be better to revert to the original setup with just one GFCI outlet (upstream from the other outlets)?
