I generally like to use a small drywall knife. Tap it in behind the tile and they will usually pop right off. A lot of the time, the drywall tends to come with it though.
Thanks. I've seen a video on doing it that way, and figured to try that also. Was wondering if maybe the m-t might be less damaging to the dry wall. Thanks again for the quick response.I generally like to use a small drywall knife. Tap it in behind the tile and they will usually pop right off. A lot of the time, the drywall tends to come with it though.
If the tile was put on properly, it's not coming off without a lot of the drywall.Never used one before, but am wondering if an oscillating multi-tool would facilitate removing 4" wall tiles from a kitchen backsplash I need to change? If so, what blade should I use? Thanks for any tips.
Thanks, Ron. Am finding out it was apparently put on properly. Looks like I'll be replacing dry wall, or installing backerboard, here shortly.If the tile was put on properly, it's not coming off without a lot of the drywall.
Ron
Thanks, Mike. You're right about that. I already ended up taking out the drywall with the tile. Took about 30 minutes. Installing backer board now. Thanks for the reply.Knute,
use your multi tool to cut the drywall above and below the tile and just take out the whole section and replace it. Much easier. The multi tools work great for drywall.
Mike Hawkins![]()
