I am fully remodeling my bathroom and installing a wall mounted toilet with the water tank inside the wall (between the studs). Bathroom is 7' x 7'
Wall is load bearing and has 2x4's 16" OC. I need to move 2 studs to create a 24" gap fro the tank. I.e., I'll move 1 stud to the left and 1 to the right.
I'm looking for tips so I don't create any sagging. For example if I nail in 2 new 2x4's in the correct location and then remove the existing 2x4's will the new 2x4's compress and get shorter? Should I try to jack the top plates up 1/16" and use new studs that are slightly long to allow for some compression?
Thanks.
PS. I know I'll have to put in a header due to span.
Thanks.
