Hello-- I a 9'x9' steel pergola on my deck (pre-fab from Home Depot). The posts are 4"x4" hollow steel. It's pretty strong, but definitely sounds hollow if you hit your knuckles on it. I'm planning to mount a small (24") TV toward the top of one of the posts. The TV is about 7 pounds, and the mount is about 2.5 pounds (mounted with two vertical in-line screws/bolts). I'm looking for the best way to mount this so that it won't put too much strain on the column, won't rip out, etc. I expect that the steel is strong enough, but I'm wondering if I should get bolts that are long enough to go all the way through the post so that there's a nut on the other side of the opposite post wall (i.e., the bolt passes all the way through the post)? Or would one "wall" of the post with an anchor be strong enough to hold about 10 pounds of weight? I'm not familiar enough with shear force and construction to know if this whole plan is unwise. 10 pounds seems reasonable, and I know that the thickness/quality of the steel posts is definitely a factor. If this is possible, I'd just like to know the best option to safely mount this without screwing up the look/integrity of the pergola itself, while still ensuring that the TV will stay mounted. Is there a particular type of screw/bolt that would be best? I live in MN, so weather extremes are a factor. The TV itself can be easily removed from the mount, so it will either be covered or brought inside during storms, winter, etc.
Another option: Would adding a small piece of wood between the mount and the post be of any value? It's not great aesthetically, but if it's going to add integrity to the setup, I'd consider it.
Thanks,
Jeff
Thanks,
Jeff
