Hi. I want to flush mount a junction box in stucco so I can attach an outside light on my garage. I don't know how thick the stucco is or if there's plywood underneath, etc. Here are my questions:
1. If I hit plywood, can I screw the box to it (instead of a stud)? This way, I assume I can just then drill a small hole in the plywood for the romex, instead of having to cut a much larger hole in the wood to accommodate the box.
2. If it needs to be attached to stud, what box do I use? (I've seen metal boxes with side brackets but the brackets are too long to fit through the stucco or easily drive screws in.)
3. Does the box type (plastic vs. metal) or shape (round vs. octagon) matter at all?
Thank you for the help.
