I currently have a telescopic TV antenna mast bolted to a 4X4 corner post of out deck/pergola. When we build a new deck or porch, I need to move it, and I want to put it on the side of the house, in the ground.
What do you suggest I use to do this? Set a galvanized pole in the ground in concrete, then mount the telescopic pole to that? That would last longer than setting a wood post in concrete, correct? What size hole and depth would you suggest?
Thanks.
Thanks.
