I just moved into a new apartment that has no ceiling fan in the bedroom, but I was told by the manager that it's fine to install one. When I removed the cover plate in the ceiling I see some kind of plastic tubular mount with small outer holes where the plate was screwed in and two larger inner holes with screws already in them.
The fan I bought has two 3" wooden screws with washers and a round metal mount with rubber noise dampeners. I'm not sure exactly how this mount needs to be screwed in or if I'm set up properly to do this. The wood screws are too thin to screw into the large inner holes and also too long (you can feel them start to hit wood or something and resists turning). They are too large to fit into the holes that the cover plate used. If I try using the existing screws that are in the wide holes in the ceiling there is not enough length to go through the round mount and into the screw holes.
The articles and videos I have searched through do not seem to address this problem I'm having. Any help would be appreciated.
