1 - 10 of 10 Posts
You measure the distance, accurately, and cut the wood.
Trick question?
Ron
· Registered User
· Old School
I need to know how to cut my moulding to fit nicely up against the existing door trim.
Your baseboard molding often looks like it is too thick to fit flush against the back side of the door casing because you are looking at the rounded edge of the casing. In actuality, if you cut the baseboard neatly and squarely, it will just fit in there without sticking past the front of the molding. A little caulking on your finger will help if the cut is not perfect.
HINT: It helps if you cut the baseboard just a tiny, tiny bit long....... you can always trim or sand it shorter, but you cannot add wood already sawn off.
Wood Butcher
That's why they call you guy's Wood Butcher's you don't have a clue, about Manufactures Warranties. ( That's why they have classes to follow their Specs.
( Not your so called )
measure, mark, cut, nail. get paid, the basis for what we do!!!
Any Fool follows your rules.
Come on reply show your ( IGNORANCE ).
1 - 10 of 10 Posts
