I just bought a used motorhome (1985 Ford Elderado) which has a lot of oxidation build up on the exterior - does anyone know how to remove it? or a compound that will remove it? I believe the exterior is fiberglass. I don't know if just a buffer would work or if I need something as an abrasive?
magic eraser. you are talking about rust on fiberglass running boards and such? be carfull though, it will remove your paint if you aren't.
I would probably use Mequiars paint cleaner.
You can try there call center for more detailed advice , I've called them before, very helpful.
CALL
Our trained appearance care Specialists are here to take your calls six days a week.
1-800-347-5700
Hours: M-F 6 a.m. to 5 p.m. (Pacific)
Saturday 7 a.m. to 3 p.m. (Pacific)
