I replaced the motor on a wood furnace blower. It was an old( ~30 years) Fasco motor. The replacement indicated is a Fasco D-150.
I have a fan center with no labels. I think it is Honeywell R8239-AT72H.
I also have a Honeywell L4064 Fan limit switch (jumper removed).
The original problem was that the old motor would not run - it would just hum.
I ASSumed the motor was bad. I also wanted to use the variable speed motor so I installed a 3-way switch. I used the feed (Fan/Load) from the L4064 to feed the switch then connect one output to the black (high) wire to motor and the other output to the red (low) to the motor.
That is really all that i changed. Also had to add a 5uF/370 capacitor for the new motor.
I connected the white wire from the motor to the white back to service panel along with other whites. This is how the old motor was.
Instead of connecting the wire (fan/load) from the L4064 to the motor it now go through the 3-way switch.
When I applied power the motor hummed, crackled, then caught fire.
I checked the voltage from the 3-way swith and it is 110v on either lead depending on switch position and the other lead is 0 volts so it appears to me that the switch is working ok and not double feeding the motor.
What in this situation do you think could cause the motor the catch fire?
