1 - 10 of 10 Posts
I have a Leviton motion sensor switch I want to use. The switch in my garage is a rocker light switch, not one of the older ones. It goes to a fluorescent light with the long light tubes, not a regular bulb light fixture. Is there a reason why it wouldn't be changeable to the motion sensor?
I tried changing the switch out, but when I turn on the power, the light doesn't turn on. I didn't try the motion sensor in darkness, I don't know if that would make a difference.
I can't figure out what's wrong. Any ideas?
Super Moderator
Did the motion sensor require a neutral? Did you have a neutral? Not all white wires are neutrals.
Does the motion sensor say it works with fluorescent lights?
Yeah, most motion sensors won't turn on if there is daylight present. They're intended for passage lighting, not work lighting.
As far as not working with a ballast, that would make sense if the motion sensor does not have a neutral wire. Try rewiring the circuit to add an incandescent bulb to the circuit, that may take care of it. If it does, adding a LUT-MLC dummy load may take care of the problem.
Discussion Starter · #6 ·
Leviton Decora, No IPS02. The box says "controls: LED/CFL, Incandescent, Halogen Bulbs, Ballasts and Fans.
When I pulled out the old switch, there was the ground wire attached to the green screw, and two gray wires. I think I tried both configurations, either wire to either of the sensor switch's screws, but nothing worked. Did I damage the switch by connecting it wrong?
I tried it with the garage door open, so it was light. I think I'll try again with the door closed.
appliances
Assuming that the Neutral & Ground connections are the same, current-wise,
there are three places in the 3 legs of this triangle that the N/G connection can go.
You should find it.
.......120v source
load__________switch
There is also an N-G-H triangle but that is another issue.
Super Moderator
You should find it.
.......120v source
The ground should not be carrying current.
Discussion Starter · #10 ·
Finally got around to dealing with this issue. I had the garage door open before and with light flooding in, it didn't work, but when I tested it with the garage door closed, it worked properly. So, problem solved. Thanks everyone for your advice and replies.
1 - 10 of 10 Posts
