Well, we've begun experimenting with removing the mortar from bricks. For those who missed the previous post, I have about a thousand bricks that I need to remove the mortar from. At 20 minutes per brick, I'm going to be doing this for a long time.
I'm using a pneumatic hammer on a Campbell Hausfeld HL4101.
Gallon Capacity: 8 Gallons
Max PSI: 125 PSI
SCFM @ 40 PSI 4.3 SCFM
SCFM @ 90 PSI 3.7 SCFM
Running HP 1.3
Voltage 120V
The problem is that this compressor won't turn off. All the while I'm working on a brick, this thing creats a real racket that keeps going until 5 minutes after I put the pneumatic hammer down.
So, the question now becomes what size/kind of compressor should I be using? My little Makita MAC700 is more powerful than the HL4101 but lacks the tank size. I look at other compressors and they're all over the place, from 1.3HP and 40 gallons up to 5HP and 20 gallons.
The pneumatic hammers are all over the place from 3 SCFM to 6 SCFM. I'm using in-line filtering/drying/lubricating and I'm running 90 psi line pressure.
Any insight would be appreciated.
Allthunbs
Max PSI: 125 PSI
Running HP 1.3
Voltage 120V
Allthunbs
