Is there an easy way to remove an old mortar bed from a block wall? I am renovating a 1950's bath where there was a pink ceramic tile shower. This is on 2 exterior walls made of concrete block and the mortar bed was about 1 inch thick. The tile has been remove down to the first coat with a hammer drill with chisel, but there is 3/8 to 1/2 inch of first coarse/scratch coat mortar still on the wall. Because the space is small, just building a wall in front of it is not a viable option. It is the intention to put 1x or 2x (on the flat) firring strips on the wall with foam between the strips to insulate the wall.
One possibility is to use a grinder and wheel to remove portions of the mortar bed and just shim the firring strip out, then insulate the space behind the firring strip with canned foam.
Any suggestions would be appreciated.
