ok i want to see if this is right, main panel has only ground bar with main ground and all neutrals attached to it. i am putting a 60 amp 2 pole breaker in and running the 2 legs to the main bus lugs in the sub panel. i would connect a wire from the main panel ground bar to where in the sub panel? (it has only one (neutral?) bar. )
