1 - 7 of 7 Posts
Registered User
Two different beasts... Mold Resistant; 1/2" thick board, ceiling framing only at 16"o.c., never 24". 5/8" will go 24". with a water-based finish.
Green board, 1/2"; ceiling framing only at 12"o.c., need 5/8" for 16"o.c. 24"o.c.--- use another product. I'd use lightweight 1/2" spans (24"o.c.) equal to 5/8" for anti-sag, and insulation weight loaded above (2.2#).
http://www.usg.com/rc/data-submitta...gular-and-firecode-cores-submittal-WB2390.pdf
http://nationalgypsum.com/products/..%5CFile%5C1046.pdf
Post #6; http://www.diychatroom.com/f101/drywall-above-shower-170011/
Gary
Mold!! Let's kill it!
Not all greenboard is mold resistant. Moisture resistance and mold resistance are two different things. Ask for a "cut sheet" where you buy it and read the specs. Mold resistant drywall is typically moisture resistant by nature, but not the other way around.
Registered User
It is my understanding they are doing away with the greenboard. I guess phasing out would be a better term. So what is out there now is just the remaining stock they are getting rid of.
1 - 7 of 7 Posts
