So last day of holiday vacation I walk through my garage and catch a glimpse of something not right up in the ceiling...black mold on the drywall. Typically this spot is hidden when the garage is open hence the reason I never saw it.
The plywood looking wall is the area of concern (I took this picture after I removed the drywall).
Here is a closeup if the spot.
I went in the garage attic and it looks like it’s coming from further above. I don’t think it’s the roofing because the sheeting isn’t wet or moldy. It looks like it’s running down the wall sheeting (forgot to take picture of wall sheeting for the 2nd story from within the attic).
So I climbed on the roof and the only thing that stood out to me was this corner trim.
It sticks out past the j channel and if you look into it, I can see the house wrap. So I suspect with the wet fall and winter we’ve had that water is blowing into here, then running down this channel along the house wrap and following it into the attic and down the wall into the garage.
I made a cap for it just in case as this didn’t seem right.
Would you all agree with my hypothesis?
