Are you assuming the exterior is leaking it and that is why you want to seal it?
Are you sure the shower stall was not leaking?
Joey
Joey
You want to kill the mold spores first, then seal the area. The paint will just seal it.Thanks for the comments.I hope its minor. I have previously sprayed with concrobium last fall, when it was too cold to tackle. I was debating if it could be sealed with paint or shelac. Once the new tub goes in I cant get access again. Just mystified that the moisture pattern seems to be creeping sideways from the corner area of the tub surround which was open topped...
On the outside wall there is a vertical tudor board in this area. I am now wondering if the water actually penetrated from a joint outside where the plaster meets the tudor board. However since the mold appears to stop about 16" above the floor, that is also the approximate height of the adjoining roof peak. Tring to determine the source.
Are you certain that BINZ or KILZ will stop this?
Spending $1000. for a one time use? Seems a little unnecessary to me with other effective and less costly measures available.Frankly I would like to back cut the 2x4's using a saw zaw to get ride of the molded 2x4s relace the pieces with new wood and sister on support pieces.
if this is not your choice, then there is an OZONE machine that replaces oxegen with Ozone gas for around four hrs to that area. I will kill anything leaving in that area. that means closing off that room for four hours. It's not a deadly gas, but a none oxegen and none explosive gas, thus living creatures will die. mold,bugs, you if you were to stay in that confined space. I bought two machines and there is a company out there cold A to Z ozone.
I got mine from island breeze technolies, around a grand a piece. if the wood is still strong, it will be mold free when your done.
Dr Durite
