1 - 6 of 6 Posts
I got a moisture meter to determine is a water stain in my kitchen ceiling old or from a leaky pipe been monitoring for 2mos.
Anyone here know what is a typical moisture content range should be in drywall?
In New Jersey (so not particularly humid or arid climate)
retired painter
I've never used a moisture meter, I usually go by sight and feel. Maybe you could use the meter in another area where you know it's dry to use as a comparison.
Moisture reading for Gypsum plaster when cured & dried is 6%.
For drywall I would think around 6% or lower would be acceptable being drywall has a gypsum core.
Discussion Starter #4
It leaves holes in the walls so I did a bunch of readings in the bedroom using the same 2 puncture holes over a week or two (eventually the holes got too big to be usable)
Bedroom is 1.3% lower on average, but all readings in drywall fluctuate from 3.5%-9% (ie 5 readings,same spot,over 3min).
(the calibration thing it came with always reads 18.2-18.3%, so its just crappy at reading drywall)
The most accurate way I've found to check moisture percent is to take a sample and use original weight vs dried weight. Maybe you could do one of those drywall pumpkin patch jobs without the hinge flap to repair the hole.
What is above the kitchen, any plumbing? Maybe a bathroom?
I use an infrared camera (not an IR thermometer). If there is any moisture present the evaporation produces a cooler reading. They rent cameras also.
Bud
1 - 6 of 6 Posts
