Hello Everyone, and thank you in advance for any help you can give me.
I live in a 3 year old, 6-unit, brick (not split-block) condo building in Chicago. Like many new construction condo buildings in the city, we have had issues with water intrusion - made evident in the form of trim/moulding splitting apart or baseboards coming away from the wall.
We had a professional inspection, and received many quotes from qualified masons. Just last week, our mason completed a 5-day job which included - spot tuckpointing of all walls, sealing of all exterior walls and roof parapet wall, replacing a portion of flashing underneath cap stones, and caulking all exterior fixtures. Our inspector agreed with the scope of the work. They seemed to have done a good job, but only time (and rain) will tell.
Now to my question. As I said, most of the water intrusion was manifest around window trim that was coming apart. However, in my master bedroom (west wall) there is a 4 foot long portion of the baseboard that dramatically peeled away from the wall. I should note that this portion is not near any windows or other exterior openings. A few months ago, in frustration, I tore off this portion of baseboard to see what was going on behind it. There was spotty black mold and dampness. I also tore off some of the drywall. Anyways, I cleaned off the mold and haven't looked at it since..
Last night, I happened to peer into the hole again, and noticed that behind the vapor barrier, the lower furring strip was pretty soaked, and the nearby insulation was also wet. I am confused because, while we did get some light rain last weekend, it was after all the masonry work had been completed. I tore away some more drywall, and opened up the vapor barrier to see if it would dry or stay wet. This morning it appeared to be drying.
My question is - could the moisture I discovered simply be from prior to our masonry work that was just "trapped" in the walls? And if so - what should I do? Seems I need to somehow open up the wall and let the moisture dry up .. I've already destroyed a chunk of the wall, so replacement work will be necessary anyway.
thanks!
thanks!
