I believe I have an attic air circulation problem which hopefully someone can suggest ways to correct. There are water droplets forming on the protruding roof nails and in freezing weather frost on the wood.
I have a two story colonial home. The home attic area is about 900 sq. ft. The 2nd floor temperature is kept at 62 degrees F during the winter. We had both a ridge vent and continuous soffits on each side installed ten years ago. Original gable vents are blocked.
In September a layer of shingles was removed. GAF Deck Armor and 6 ft. of GAF Weather Watch to help prevent ice dams were applied. GAF Timberline HD shingles and a GAF Cobra ridge vent were installed over the entire length of the ridge.
In November-December of this year the problem started when there were quite cool temperatures in the evening here in New Hampshire. The entire roof was affected. The attic temperature was 37 degrees F and the outdoor temperature was about two degrees colder. The R factor of the attic insulation is about 50 with baffles between attic joists. There were no condensation and frost problems with the previous roof and ridge vent which I believe indicates the ridge vent was cut to the proper width.
A new bath exhaust fan is connected to a duct leading to the roof vent which is working properly and is run for 10 minutes after showering.
Some checking on line for better ridge vents found Air Vent II with a baffle which promotes better air flow was an option I am considering.
My questions are:
1. Do you think changing to the Air Vent II ridge vent would correct the problem?
2. What should the per cent relative humidity of the attic be compared to the outdoor humidity?
3. If the Air Vent II doesn’t correct the problem, what would you suggest?
4. Any thoughts of a possible roof fan controlled by a temperature/humidity control?
I greatly appreciate your valued comments. Thank you.
My questions are:
