Hello Everyone,
I am currently building a new home (first one) and am in the process of having the architectural drawings finalized. As background, I picked stock drawings from an Internet shop (houseplans.com) and had an online draftsman modify them per my changed floor-plans. I know it was risky but several people on line had good experience with these stock plans and the total cost was about 3k as opposed to architects in the Boston area who wanted 20-30k.
Unfortunately after buying the plans I found out that the original plans do not have separate structural/foundation plans or framing plans but combined the structural info (foundation, beams, joists etc,) on each floor plans. Moreover I also discovered that the plans have a date of Oct 2000 on the front page, a copyright from 1988 and a signed date from the designer of 1986; which is an issue as I’m sure codes have changed over the last 25 years. So I guess you do get what you pay for but I think I'm still better off than going with a local architect.
My question is, who would be the best professional to hire to get these plans in buildable order.
I’m thinking the following would be required as a minimum.
1) review plans to make sure that everything is up to code and the structural integrity is still intact.
2. 2) Modify the foundation to fit on a sloping site and incorporate a walkout basement.
3. 3) Develop more detailed and separate structural plans
4. 4) Develop more detailed and separate framing plans
5. 5) Develop material takeoffs
Also how much should I expect to pay for this type of work? Assuming I'm using a PE or architect, should I have them be responsible for acquiring permits as part of the work?
Also what you’re your thoughts on using a lumber yard’s engineering staff. I noticed the National Lumber offers engineering services/engineering plans as well as material takeoffs. Is it safe to go with a lumber yard or am I better off spending the extra money for an independent engineer.
Thanks so much in advance for any help/advice you can provide
Jim
Jim
