I would buy a fan that uses regular Edison base lamps. Then decide whether you want incandescent, CFL or LED lamps. Make sure the ones you buy are dimmable (if CFL or LED). Wire a hot and neutral to the switch box and a 3 wire cable up to the ceiling box. Buy a dimmer compatible with the type lamps.
