The only time you would need 8" pipe is if the entire home had all its branches/pipes coming off that one pipe.
In a regular home you have a plenum and it may be 16" wide and the take off is 8" so you have a 8"x16" square duct ( just using round numbers as some are smaller or larger ).
Then it travels 6 feet and tapers down to 8" x 12" or 14" and later 8"x 10". The takeoffs to the rooms are usually 5" or 6".
I have seen 2-3 story houses with 6" pipe running 20-30 feet up and around joists then going to the upper floors so 6" is as large as we usually use.
Stay with the 6" pipe BUT seal every joint tightly with silver foil duct tape from HDepot so you does not leak air out.
