Hi all -
I am in the process of replacing the subpanel in my house. I have 200-amp service that comes in overhead to my main panel. From there it runs underground with mobile home feeder wire to the subpanel. Since I am upgrading the panel, I also have to upgrade the service line to 4 wire.
The main panel is roughly 5' from the house, so the new cable only needs to go underground a short distance where it will go under the footing/foundation and enter the crawl space. The distance that it will need to run in the crawl is roughly 20-25' (the area below the new sub). Now finally, my question is, does it need to be run in conduit the entire way within the crawl space? I will have conduit from the new subpanel down into the crawl as well.
I realize it's only a short distance, but ease factor would kick in if I can run the new service line along the bottom of my floor joists vs running it in conduit along the floor. Thanks for any help you may offer.
