mobile home dimmer switch
6215 Views 4 Replies 5 Participants Last post by  Oso954
I'd like to replace the wall switch with a dimmer switch in my mobile home. The current switch is a self contained switch without a wall box. The switch fastens directly to 14 AWG Romex. Where may I purchase such a switc?
You need to Kill the power, cut the wires, install a cut-in switch box, then install a standard dimmer.
It's called an old work box, looks like this.
Make sure the walls are deep enough to install one before buying one.
http://www.bing.com/images/search?q...C24EDDCC333A8051BCAE1580026412C09D7A8&first=1
Often time mobile homes have paper thin walls.
depth shouldnt be a problem, we have replaced receptacles in two mobile homes and neither had any problem fitting the old work boxes, even the walls made of 1x3's fit without a problem. Not contradicting you, Joe, just my two cents. good luck bill
This one works well for shallow spaces.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=202077341&storeId=10051&langId=-1&catalogId=10053&ci_sku=202077341&ci_kw={keyword}&kwd={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-202077341&ci_gpa=pla#.UL5Rs4awV7k
