1 - 6 of 6 Posts
Hi everyone, I live in a single wide 1999/2000 mobile home and am beginning some repairs/changes. I would like to replace the closet doors with mirrored either sliders or bifold. The trouble lies in that my current doors are 88" high, with the opening being approx 90" in height. I live in a remote area with no mobile home specific building supply stores. I am wondering how easy/expensive it would be to either diy my own closet doors (I have virtually no construction experience, but follow instructions well) or do you think it wold be best to get some ordered from my local building supply store? Apologies if this has been covered extensively but I had unsuccessful searches. Thanks ahead for any help you can provide, Cheers!!
You're not going to do this with your experience. Substrate, mirrors, hardware connection? I'd order one and be happy you could install it.
Ron
Discussion Starter #3
Thanks for the info,
I'll get in touch with our building supply place and see if it's cost effective to order new ones.
If not I may consider doing the whole glue the mirror to the existing door thing or mirror tiles or.......just painting the door panels as they are and replacing the messed up rollers I have.
Glad to have some input, thanks!
Cheers!
I've made Bi-fold doors from MDF that you could stick the adhesive tiles to.
The track and roller hardware kits are available through your local Home Hardware.
(Canadian, I see. Me too)
Cheers!
If you start adding weight to the door, remember that the hardware was designed to carry the door as it was produced. If you switch the hardware, make sure it will carry the increased load.
Ron
Discussion Starter #6
Thanks for your feedback, I'll research the mdf path and see whether it's something I feel I can tackle when I find plans and glad to get the heads' up on the hardware.
The existing hardware is shot on the one closet so when I go to replace it I will just go with a heavier duty type in case of future weight add ons or heavier doors.
Cheers!
1 - 6 of 6 Posts
