An old log cabin I am thinking of remodeling has no separate safety ground. Two ground electrodes (ground rod, well pipe) connect to neutrals at the meter base, in a junction box, and at the hot water heater.
Definitely not to code. If I isolate ground connections and connect them directly to the main panel, there may still be "joints" between neutral and ground that I haven't found. How unsafe is this and why?
Thanks,
Daneel
Thanks,
Daneel
