i have an issue...
just bought a house with the recessed dryer vent box...the pipe that is suppose to go through the "oval" hole appears as if it was either cut off or wasn't installed the 2 inches or so through, into the box portion. It appears the recessed box was actually cut to the round shape, instead of forming to the oval...the pipe is pretty much flush with the recessed box
so, i'm curious what the best countermeasure is to hook up my dryer?
is it simply to add a say...5" piece that inserts inside the existing pipe, then use that to tie the foil/aluminum hose into? seems easy enough, but i worry about the heat/lint getting past the metal on metal "joint" and into the framework since i can't tape off the joint..
suggestions??? thanks in advance!!!
