1 - 7 of 7 Posts
I have a wall in my living room that is mirrored. I really like the effect of the mirrors (illusion of more room), but I do realize that it dates the house. Is there anything I could do to update these mirrors?
· long island, NY
honestly, probably not. However, that doesn't mean that there aren't other ways to visually increase the size of a room......
solid and light wall colors (no chair rail, patterns, or boarders). Light colored flooring.... if wood flooring, the planks should run in the same direction as the shorter walls.. this visually elongates them.
Have light colored and thin curtains that go from floor to ceiling.
furniture can also make a room look less cluttered and more spacious...
glass tables
smaller scaled furniture
low profile furniture (side board instead of tall china cabinet)
avoid bulky chairs or oversized china cabinets
hope this helps :)
· Stuck in the 70's
You might get more response with more information (a pic would help). How big is the wall? How big is the mirror? Is the mirror one piece or those 12" squares?
I saw a pic somewhere. Someone took a bunch of 12" mirror tiles and used trim between and around them to give the impression of a latticed window. A narrow shelf was then added below as a sill.
mirrors
Many people like the look of a large mirror on the wall in their home or apartment. In addition to being useful to check out your style and appearance, many people believe that they can be effective in helping to make a small space look larger. It's important to be careful when hanging a mirror. A big glass mirror with a wooden frame is probably a lot heavier than the photos you normally hang on the wall.
You need to be a bit more careful when hanging it. Most photos can be hung with a single nail. Heavy mirrors should use a hook that connects to the wall, and ideally two or three hooks. Sometimes the hooks can lock in order to make sure that even a strong earthquake will not dislodge your mirrors and send them crashing to the floor. :)
Brian
http://miceexterminationforbeginners.blogspot.com/
1 - 7 of 7 Posts
