1 - 9 of 9 Posts
The wife and I are going to frame out our big bathroom mirror with the trim I've attached here. She wants to put each piece up 1 at a time by glueing up with epoxy but I think we'll get a cleaner looking frame if we assemble the frame first and then glue up to mirror.
Frame is going on TOP of mirror so we'll be glueing it right onto the mirror.
My question is: what method would you recommend for assembling the frame before putting up on the mirror?
That looks like flat window molding, it has no rabbet to go over the mirror. If it is bigger than the mirror it will leave a space between the molding and the wall, if it is exactly the same size as the mirror, you will see the mirror along the outside edge of the molding.
To assemble that I would use wood glue and a right-angle clamp or two. It looks like there is a relief on the back that might be deep enough for a piece of cardboard or thin veneer as reinforcement. Once it's complete glue it to the mirror with a few dabs of silicone sealant.
I've done this many times and always cut a rabbet on the inside edge of the casing to accept the mirror so the molding sits flush with the wall and mirror.Make it a little wider than you think you'll need so you have a little wiggle room.
· JOATMON
I've done it a couple of times.....some advice.....
Remove the mirror and make it a part of the picture frame. As noted above, you want to notch the inside so the glass fits in it.
Make that rabbit groove about 1/4". Then before putting in the mirror, paint the inside a light color and let it dry completely.
Once dry, run a bead of clear silicone around that rabbit and then set the mirror in.
That will hold it quite well. The frame and mirror become 'one'.
Or, use white silicone.
If you don't paint or use the white silicone, you end up with a dark seam due to the thickness of the glass reflecting the backside of the rabbit. Using a light color such as white or gray makes it pretty much disappear.
1 - 9 of 9 Posts
