1 - 20 of 35 Posts
I made a jewelry box for my girlfriend. I stained it dark oak, then after it dried, I put a coat of minwax fast drying polyurethane satin finish. There are all these light yellowish blotches in various places, some are really ugly and large. How do I correct this?
Thanks for any help you can lend. This is how it looked before I put the finish on:
I am in Washington, DC.
Remodel and New Build GC
Are the blotches former air bubles... or your stain had stearates in it and was incompatible with polyurethane.
Try sanding them down if they are bubbles, and stir the poly... did you shake it
Discussion Starter #3
They aren't bubbles... i just realized it's kind of a film, and I hope to be able to sand it off. It was a minwax stain, so doubt it was incompatible.
Hey, thanks for your quick reply. Should I sand?
Always best to apply more then one coat of poly.
Sand between the coats.
Reactions: knowmoore
Discussion Starter #5
This is how it looked after the minwax... so you're saying I should just sand and re-coat?
THANK YOU FOR YOUR HELP!!!!
Are you sure you did not use water based stain instead of oil?
How long did you wait for the stain to dry.
It looks like the poly wiped the stain off.
Knowmore...
Sometimes a birch ply, or any ply, but mostly a soft ply, can take a stain irregularily. A coat of sanding sealer will semi close (even out) the poristy and take the stain more evenly.
Realistically, probably can't sand it out now.... but what about your lady's favorite color... purples and maroons are good for getting..OOPs Edited.
A lite, maybe 180/220 paper sand will prepare it, and several spray coats can still revive it... you'll have to tape off the drawers... and don't overcoat a spray coat... it'll run.... just multople light coats... drying for 30 minutes in between... and I'll bet she loves it.
Just my idea...
Good Luck
knowmoore said:
I used an oil-based stain, and I waited 3 or 4 days for the stain to dry.
That's odd then. From the pic it looks like an issue with the stain rather a odd colored area in the varnish film. Does it look to you like the stain just came off in places?
If you bough the box from a craft store or something, or the wood is of unknown origin, it could easily have had some sort of sealer or contaminates that kept the stain from penetrating.
Environmental conditions could have affected it also. In a dark,and/or damp area, it might not dry even in a few days.
For your sake, I hope I'm wrong. Tough to fix.
Discussion Starter #12
The stain was pretty heavy. Maybe it didn't dry evenly. Is sanding and recoating the best move?
Thanks you so much.
Retired Moderator
What kind of poly==exactly--water based or oil?
I suspect water based---but tell us---
Knowmore...
Just one more idea, if ya wanted a very real dark stain, you could recoat with a stain colored poly. the stain is in the poly and I think it's called PolyShade in Minwax.
You would not be fixing it as much as camoflging it so to speak... you would still see shading... just less so.
But you have to put it on with a real good brush and very evenly, because the stain (more of a coloring) is in the stain, and if it's heavier one place it will be streaky... very important to put on running with your grain. Scuff sand between coats.
Just an idea
Good luck Bubbi
Well... yes you could... do you have a belt sander....use carefully. and subsequent palm (finish sanders)
You would have to be carefull to not go thru a ply (on your sides). I looked at the pic and think thats solid 1x on the top. Alot of work, but possible ... and sand carefully... especially near your edges.
Do you know what edge banding is... after sanding you could apply edge banding (glue, press on, or iron on) to the plywood side edges for a finished look. Edge banding...about $5 at any big box.
Too Short? Cut it Again!
Did you seal the wood before staining? Did you apply the stain and wipe off the excess? Did you stir the stain thoroughly? I ask because you mention it was thick.
Gel staining it now might work out. It will not look like real stain and poly finish though.
oh'mike said:
Water based poly or oil based?
They have started putting 'fast drying' on the regular oil base Minwax Polly. Idk why, its still slow to dry, 4 hours at best.
You would think they would label the WB 'fast drying' it dries in as little as 1 hr.
1 - 20 of 35 Posts
