Thats what I was thinking. My father was dumbfounded when I told him I didnt see a code for height. So I wanted to double check with you guys! And I was going to copy the rest of the house anyways but just wanted to make sure there wasn't something I was missing!i have never seen a height requirement specific to a basement. The common practice is to simply make them as high or higher than the ones in the rest of the house. Most codes deal with distance from each other, like you mentioned
16 Oz Stanley hammer off floor to bottom of box :}:}} seems to be the "norm" around here :}
Well Norm don't work here. :whistling2:16 Oz Stanley hammer off floor to bottom of box :}:}} seems to be the "norm" around here :}
Yes they must be below 5.5 feet. They can be in the floor if you wish as long as they are within 18 inches of the wall they can be counted as part of the required receptacles.isn't the height that is too high like 6' or more?
Most of the houses I do end up in the baseboard... go figure.16 Oz Stanley hammer off floor to bottom of box :}:}} seems to be the "norm" around here :}
Does the Canadian code have required receptacle spacing along a basement wall?The only height restriction if you put them too high you can't count them as part of the required receptacles along a a wall.
Now that is extreme there Petey. But kind of an interesting idea. I'm due for a new gadget now that I am doing more residential. I'd be the talk of the county. :laughing:Put it this way, I bought a rotary laser just to make sure the receptacles in big kitchens are EXACTLY the same. :thumbsup:
more than one i've used a transit... you do what you have to do.Now that is extreme there Petey. But kind of an interesting idea. I'm due for a new gadget now that I am doing more residential. I'd be the talk of the county. :laughing:
Yup. Especially when the.....you do what you have to do.
It does if it is finished space. Same as NEC 6/12 foot rules.Does the Canadian code have required receptacle spacing along a basement wall?
I see, thanks. But OP didn't mention creating a finished space. Just installing receptacles.It does if it is finished space. Same as NEC 6/12 foot rules.
