1 - 2 of 2 Posts
Hi,
I have a Fujitsu mini split AC and the condensor is installed on the roof. The roof will be redone shortly and I need to remove the unit for them to work. My unit is working fine, Can I unplug it and replug it afterward by myself? Do I need any special device like a vacuum pump or can I just disconnect the the tubes and reconnect and it will work again without problem?
Thanks for advice!
· In Loving Memory
Need to either pump it back to itself.
Or recover teh refrigereant.
Then vacuum the lines when its reconnected.
1 - 2 of 2 Posts
