I have a tiny home type building with two upstairs lofts and a barn style roof where the peak of the roof is around 12 feet tall.
The building itself is 16' x 34', so 544 sqft total. Under the loft is a 16' x 10' room (160 sqft) that is fully enclosed by a wall.
I need a dual zone mini split heat pump system.
Zone 1 would be the 16x10 room (160 sqft) underneath the loft with a ceiling height of 6 ft 8 in.
Zone 2 would be the entire rest of the house which is 384 sqft (544 - 160 = 384) plus the upstairs lofts.
I live in Texas where summers are consistently 90-100 degrees and winters are pretty mild with random spurts of barely freezing temperatures. The building will be spray foam insulated with open cell spray foam.
Based on my own research I figured Zone 1 (160 sqft) would need an indoor unit around 4000 BTU and Zone 2 (384 sqft plus upstairs lofts) would need an indoor unit around 12000 BTU.
I just wanted to get some feedback to make sure I'm not oversizing or undersizing the system by too much. I've been looking at Daikin since they seem to be a top recommended brand for mini splits, but I was curious if it's worth the extra cost since they're pretty expensive or if the slightly cheaper brands are just as good.
