Hi!
I am new to this forum but not to DIY. I am looking for feedback on a very atypical HVAC project I have. I couldn't find any similar project anywhere on the internet.
I would appreciate all constructive feedback! (but please read the whole post before answering):vs_cool:
Long story short, I need to replace my split heat pump HVAC system currently in an uninsulated attic. I plan to insulate the attic and to put 1 mini-split IN THE ATTIC, then add ventilation through the ceiling to cool down the whole house. :vs_bulb:
( my house: 1953 1300sqf Florida ranch style, 3bed/2bath 2living room 1 office 1 kitchen 1 laundry, not open floor plan. Gable roof with ventilated and not insulated attic, small crawlspace)
I did a LOT of research and I think this might actually be a surprisingly efficient and cost-conscious alternative to spending $20,000 on a full removal/ installation of a new system.
Why can't I just keep my current HVAC or upgrade to similar system?
- ductwork is in uninsulated attic (in Florida!). I cannot insulate the attic as the ductwork takes the whole space (attic is very small). I cannot even access the attic. In fact, I don't even have insulation on the ceiling, and I don't have access to put insulation because of the current HVAC system. On top of that, the general installation and design of this HVAC system is very poor, and the lack of space also means the ductwork is very poorly done and highly inefficient.(sharp bents, compressed ducts, etc.). I highly doubt that paying for new ductwork would result in a much better result due to lack of space and bad location of air handler / outdoor unit. And that still leaves me without insulation and access to my attic.
What are the other options?
- relocation : I don't have anywhere else I can put it (I have a small crawlspace, but it is too small and therefore not an option).
- High velocity : too much work for retrofit and way too expensive.
- Ducted mini-split. Other than being way overpriced, these unit also do not work for 5 or 6 zones (which I would need). It would mean several units inside and outside, a lot of complexity, a lot of cost, and without even the added benefit of zoning cooling (as one unit would be used for several rooms).
- Ductless mini-split. I keep going back and forth with this. I really like the idea of cooling by zones, but the problem is the number of units / the location. If I put it in a room, what about the other rooms? with 3bed, 2 baths, and 2 living areas + kitchen (and not an open floor plan) this would mean a lot of units, or/and a very uneven distribution of airflow. Having 4 or 5 units would mean way more BTU's than I need, and also the added complexity of 5 things to maintain, repair, etc. It is also quite pricey.
For a while I thought that my only solid option was to go ductless with 5 zones (one in each room, 1 in kitchen, one for living areas), which is a little ridiculous and overkill for a small house like mine.
And then I thought: why not remove the whole system, insulate my attic very well (making a hot roof and include the attic in the conditioned space) and then put a 30,000 BTU mini-split in the attic. The attic would then be cooled evenly, and I would add a small ceiling fan to each room to bring the air from the attic to each room. My attic then acts as a "plenum" for even distribution of the air between the rooms, and ceiling fans make the transfer of the air faster (10 months out of 12 I am cooling, so cool air would go down anyways). I could maybe add a ceiling fan for a return from the house to the attic right under the mini-split.
It seems to me that I would get a quite simple, solid and efficient system this way. It will make my house 1 big room as far as HVAC is concerned. I would get access to my attic. It should be cooled quite evenly throughout the house, and that can be improved / fine tuned with the use of fans or maybe even a ERV ventilation system if needed. It allows me to fill my attic with insulation, thus tremendously improving the efficiency of my house (now it has 0 insulation). I would go from 10 SEER to 25 SEER, improved insulation, and more space (in the attic and outside unit). And I won't see the mini-split on the walls in each room. So, win-win-win, or did I miss something?
What do you guys think? :vs_worry:
