· Retired Moderator
I am reworking our main bath and above the shower I plan to drop the ceiling about 7 or 8 inches using T&G Western Cedar as the ceiling. I am installing two mini can lights made for showers in the cedar ceiling. I am not removing the ceiling that is already there because of the blown in insulation. These can lights are 5 inches tall and are remodel type, there will be about 2 or 3 inches clearance above the lights will this be enough clearance to keep the lights from over heating?
The instructions show side clearance but not over head clearance. Do any of you guys know if the lights will over heat that close.
Another question, I almost know the answer to this one already. I plan to run copper water supply pipes, for shower heads, in the dropped ceiling also as one will be for an over head shower head, will this pass code or will I need to run the pipes under the floor. The lights will be on a ground fault circuit.
Please don't suggest asking our county code department, I have dealt with asking them before, what a joke. I had to call back and talk to my inspector at 3 PM when he came in to do his paper work and he was not happy to answer questions.
· Licensed Electrician
Unless the cans specifically state a clearance, I wouldn't worry about it. There is really no standard except for insulation contact.
· Resi EC
Should have the IC in the model number of the recess can.
Unless it makes you feel better about the install, the lights do not need GFCI protection.
Just need trim 'suitable for damp locations'
edit: if there is no insulation being added the IC rating will make no difference
· Retired Moderator
While looking for the IC rating I see this can light is not to be installed where insulation is, if so it says it will need an insulation box. There is no insulation in the drop down ceiling so I am good there but it does say I need 3 inches above and a specific type of light bulb.
That is good to know a ground fault isn't needed but that is the circuit I plan to use anyway so it can't hurt. This is a designed for shower type light. It does say the wire needs to be a 90° wire though so I will make sure it is.
I really do appreciate your help fellows, thanks a ton.
