1 - 10 of 10 Posts
632499
Putting a miller cmf80 with beckett motor, trailer furance in garage. Having issues getting it to run. I turn it on. Can see a blue flame inside. it runs for about 30 seconds then stops and reset button pops. Any suggestions?
Thanks
Flame shouldn’t be blue.
What fuel are you burning, kero or oil?
Is the flame dying then popping the primary?
Kerosense fuel
I just watched flame and it was going right until the popping of reset button
Administrator
Did you bled the oil pump? If you don't bled it, it won't pump oil. The blue "flame" you think you saw, was most likely the blue spark from the ignition transformer.
Administrator
Remove the jet line from the nozzle assembly. Turn the line toward an empty open container, and run the burner again, and see if the pump is pumping oil to the nozzle.
Also, the ignitor/electrodes should be 5/16" above the center of/hole in the nozzle, and if an 80° nozzle, 1/16" infront of the nozzle.
Yep your right. No fuel coming though line. Is it a fuel pump issue since it will bleed?
Administrator
Yep. If it bleeds a solid stream of oil, but doesn't pump oil to nozzle line, its shot.
Administrator
Your welcome. While your at, since its an old burner, if the pump coupling hasn't been changed, now is a good time to also do that.
1 - 10 of 10 Posts
