Starting about a month ago, my municipal tap water gradually began to run a light white. Now it's almost skim milk white. If you fill a glass of water, the water clears after about a minute. No doubt it is just harmless oxygen or air bubbles rising to the top, but something is not right with the system.
Water from all of the hot and cold faucets in the house and the two outside hose bibs is all the same, very milky.
None of my neighbors are having any similar problems.
I went down to the water dept today to pay my bill, and while there I talked to the chief engineer of the municipal water dept. He got on the case right away and had a couple of guys check the "?pressure relief valves?" in the area, and he said they were OK This afternoon he came out to the house and had a look. He was stumped. He'll work on some ideas tomorrow, but in the meantime, do you guys have any suggestions as to what may be happening?
Water pressure to the house is a high but acceptable 80-85 PSI.
Thanks.
Thanks.
