I've spent half the day getting to this point, and realized, I think I'm kinda screwed.
I bought this big old Medicine cabinet (23x30). My first cut across the bottom was too low. I thought 3 inches above the outlet would be good (on the left side of the right stud), and I was right at the height of a horizontal brace. The problem was the wiring was a few inches over. So I added my footer a few inches higher, then cut out the bottom of the drywall to fill, (and will try to clean that up before I install). I then adjusted for it, and recut the top for the difference to shift it up a couple inches. I was in the middle of fine trimming my header to install, and realize I'm going to have a problem.
I have a 1/2" difference between the width at the bottom and the top. The drywall cut is vertically level, the stud is not. The bottom leaves me a 1/2 inch which I though would be just enough room for the electrical cable to fit, but for the top stud to stud, it is the exact measurement, I am getting off the medicine cabinet.
If this site wasn't here, I would probably use my Dremel, and a small round sander, and make just enough of a channel for the cable to fit in, then hope when it comes time to fitting in the cabinet, I can use a mallet to tap it in. If I really need to make room, I may try to sand the top right side of the opening, (the left side of the right stud).
This wall is definitely not a support wall, and is between the master bath, and master closet. Do I have a good plan, or a horrible one? Is there a better way, I'm not seeing to make this work? Thank you.
(top of this picture is the right side, should be rotated 90 degrees clockwise, I can't figure out how).
